{"product_id":"bobbed-gas-tank-set-v-twin-38-0820","title":"Bobbed Gas Tank Set - V-Twin 38-0820","description":"\u003cp\u003eBobbed gas tank set features provisions to accept early caps reserve shut off rod and two or three light dash. Tank has emblem mount strips attached.\u003c\/p\u003e\n\u003cp\u003eTank emblem mount screws not included. Tank requires sanding and primer prior to painting. Shut off fitting should be masked or plugged during painting for easy installation of shut off valve. The 1961-1962 emblem mounts are welded on for use with the OE emblem set. Order emblem set separately. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. All tanks or tank sets will require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve correct height. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Kreem Gas Tank Combo Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Replica Eaton Style Gas Cap Vented.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Stock Style Gas Cap Vented.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with OE Emblem Set with Black Lettering.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1961-1962\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552854245534,"sku":"38-0820","price":269.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0820-bobbed-gas-tank-set-1.jpg?v=1792132371","url":"https:\/\/chopcult.com\/products\/bobbed-gas-tank-set-v-twin-38-0820","provider":"ChopCult","version":"1.0","type":"link"}
