{"product_id":"bobbed-6-0-gallon-gas-tank-set-wyatt-gatling-72651-big-twin-1984-1999","title":"Bobbed 6.0 Gallon Gas Tank Set - Wyatt Gatling 72651 - Big Twin 1984-1999","description":"\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 72651\u003c\/p\u003e\n\u003cp\u003eGas tank is a two piece set and has a left side petcock opening. The set has a fuel capacity of 6 gallons.\u003c\/p\u003e\n\u003cp\u003eThis flat side tank features screw type bungs. Order caps separately. Check the petcock opening making sure the petcock can be easily installed. Petcock opening should be masked or plugged during painting for easy installation of the petcock. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to hel p stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 17-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 3-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 8 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 2-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 8-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eTunnel Length:\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use VT tank trim cover\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1986-1999\u003c\/td\u003e\n\u003ctd\u003eFLST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1984-1999\u003c\/td\u003e\n\u003ctd\u003eFXST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552812236958,"sku":"38-0122","price":249.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0122-bobbed-6-0-gallon-gas-tank-set-wyatt-gatling-72651-big-twin-1984-1999-1.jpg?v=1792131961","url":"https:\/\/chopcult.com\/products\/bobbed-6-0-gallon-gas-tank-set-wyatt-gatling-72651-big-twin-1984-1999","provider":"ChopCult","version":"1.0","type":"link"}
