{"product_id":"bobbed-6-0-gallon-gas-tank-set-v-twin-38-0129-big-twin-1984-1999","title":"Bobbed 6.0 Gallon Gas Tank Set - V-Twin 38-0129 - Big Twin 1984-1999","description":"\u003cp\u003eGas tank is a two piece set has a fuel capacity of 6.0 gallons and features a right side top vent on the inside of the gas tank and left side petcock.\u003c\/p\u003e\n\u003cp\u003eThe tank accepts caps for stock style bungs. Order caps separately. This flatside tank has an updated shape with taper from front to rear. Check the petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 14.5 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 17.5 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 5 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 8.5 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 1.5 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 10 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 19 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use with Ratcheting Style Gas Cap Set Vented and Non-Vented\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1986-1999\u003c\/td\u003e\n\u003ctd\u003eFLST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1984-1999\u003c\/td\u003e\n\u003ctd\u003eFXST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552812368030,"sku":"38-0129","price":249.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0129-bobbed-6-0-gallon-gas-tank-set-big-twin-1984-1999-1.jpg?v=1792131968","url":"https:\/\/chopcult.com\/products\/bobbed-6-0-gallon-gas-tank-set-v-twin-38-0129-big-twin-1984-1999","provider":"ChopCult","version":"1.0","type":"link"}
