{"product_id":"bobbed-5-1-gallon-gas-tank-v-twin-38-0829-big-twin-1996-2003","title":"Bobbed 5.1 Gallon Gas Tank - V-Twin 38-0829 - Big Twin 1996-2003","description":"\u003cp\u003eCustom gas tank does away with the stock fuel gauge and utilizes two right handed screw bungs to accept late style gas caps. Fuel capacity is 5.1 gallons.\u003c\/p\u003e\n\u003cp\u003eOrder gas caps separately. The tank uses a stock style FXDWG dash console. Tank is not for fuel injected models. Please test fitment before painting. Tank weld seams may require filler to meet your individual requirements. Do not grind or sand the seams as this may cause leaks. We suggest using Kreem gas tank combo kit to clean condition and seal. This will help to stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation. of petcock. The rear tunnel width is 2-3\/4 inch and the front is 3 inch\/ It is 20-3\/4 inch from the center of the mounting holes. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 18 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 8 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 15 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 2 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 8-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 6 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 18-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eBetween Front Mounts: 2-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eBetween Rear Mounts: 2-3\/4 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Kreem Gas Tank Combo Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with (2) Ratcheting Style Vented Gas Caps.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1996-2003\u003c\/td\u003e\n\u003ctd\u003eFXDWG\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552854409374,"sku":"38-0829","price":399.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0829-bobbed-5-1-gallon-gas-tank-big-twin-1996-2003-1.jpg?v=1792132374","url":"https:\/\/chopcult.com\/products\/bobbed-5-1-gallon-gas-tank-v-twin-38-0829-big-twin-1996-2003","provider":"ChopCult","version":"1.0","type":"link"}
