{"product_id":"bobbed-5-1-gallon-gas-tank-v-twin-38-0548-oem-61586-04b","title":"Bobbed 5.1 Gallon Gas Tank - V-Twin 38-0548 - OEM 61586-04B","description":"\u003cp\u003e\u003cstrong\u003eOEM #:\u003c\/strong\u003e 61586-04B\u003c\/p\u003e\n\u003cp\u003eBobbed one piece gas tank has a fuel capacity of 5.1 gallons and is a replacement type for carburetor or EFI models. The tank accommodates a left side fuel gauge and a right side screw cap.\u003c\/p\u003e\n\u003cp\u003eCheck the tank for flaws and fit before painting. Tank requires sanding and primer. Do not grind or sand the seams or joints. The fuel line fitting should be masked or plugged during painting for easy installation of the fuel line. It is suggested to pressure test the tank and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use with Low Profile Chrome Gas Cap Set Vented and Non-Vented.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e2009-2014\u003c\/td\u003e\n\u003ctd\u003eFXDC\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2009-2017\u003c\/td\u003e\n\u003ctd\u003eFXDF\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2004-2005\u003c\/td\u003e\n\u003ctd\u003eFXDWG\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552831275166,"sku":"38-0548","price":399.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0548-bobbed-5-1-gallon-gas-tank-oem-61586-04b-1.jpg?v=1792132180","url":"https:\/\/chopcult.com\/products\/bobbed-5-1-gallon-gas-tank-v-twin-38-0548-oem-61586-04b","provider":"ChopCult","version":"1.0","type":"link"}
