{"product_id":"bobbed-5-0-gallon-gas-tank-set-wyatt-gatling-70928-oem-61213-83","title":"Bobbed 5.0 Gallon Gas Tank Set - Wyatt Gatling 70928 - OEM 61213-83","description":"\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 70928 · \u003cstrong\u003eOEM #:\u003c\/strong\u003e 61213-83, 61229-83\u003c\/p\u003e\n\u003cp\u003eGas tank set uses a 1975-up petcock with nut and has a fuel capacity of 5.0 gallons. Features left side petcock outlet.\u003c\/p\u003e\n\u003cp\u003eTank accepts stock dash and speedometer. Order screw bung caps and petcock separately. Please test fitment before painting. Tank weld seams may require filler to meet your individual requirements. Do not grind or sand the seams as this may cause leaks. We suggest using Kreem gas tank combo kit to clean condition and seal. This will help to stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. All tanks or tank sets will require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve correct height. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 17-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 4 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 6-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 1-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 8-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eTunnel Length:\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use petcock for backward outlet.\u003c\/li\u003e\n\u003cli\u003eSuggested to use petcock for forward outlet.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Petcock Straight Outle with Nut Alloy.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Ratcheting Style Gas Cap Set Vented and Non-Vented Chrome.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1947-1984\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1979-1982\u003c\/td\u003e\n\u003ctd\u003eFXS\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/38\/38-0113.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552811516062,"sku":"38-0113","price":179.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0113-bobbed-5-0-gallon-gas-tank-set-wyatt-gatling-70928-oem-61213-83-1.jpg?v=1792131953","url":"https:\/\/chopcult.com\/products\/bobbed-5-0-gallon-gas-tank-set-wyatt-gatling-70928-oem-61213-83","provider":"ChopCult","version":"1.0","type":"link"}
