{"product_id":"bobbed-5-0-gallon-gas-tank-set-wyatt-gatling-011579","title":"Bobbed 5.0 Gallon Gas Tank Set - Wyatt Gatling 011579","description":"\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 011579\u003c\/p\u003e\n\u003cp\u003eGas tank is a two piece set has a fuel capacity of 5.0 gallons and is for hand shift models. Tank set includes special chrome shift lever to clear the large tanks will accept 2 3 and cast dash panels. Includes the shifter.\u003c\/p\u003e\n\u003cp\u003e*NOTE: Order shift gate and mounting hardware separately. Tank set features provisions to accept two vented early caps and reserve shut off rod. This set requires use of gas line fittings. Tank may require fuel rod alignment before installation of shut off assembly. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. it is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean con dition and seal to help stop leaks and prevent corrosion. Check shut off opening making sure the shut off valve can be easily installed. Shut off fitting should be masked or plugged during painting for easy installation of shut off valve. Accepts 1939-1964 style vented left and right caps. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 17-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 1 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 7-1\/2 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use shift gate for 4-speed transmissions.\u003c\/li\u003e\n\u003cli\u003eSuggested to use shift gate for 3-speed transmissions.\u003c\/li\u003e\n\u003cli\u003eSuggested to use Kreem gas tank combo kit\u003c\/li\u003e\n\u003cli\u003eRequires #7807-3 gas tank fittings.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with petcock#\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Fuel Cross-Over Line#\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1948-1965\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552812433566,"sku":"38-0130","price":219.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0130-bobbed-5-0-gallon-gas-tank-set-wyatt-gatling-011579-1.jpg?v=1792131968","url":"https:\/\/chopcult.com\/products\/bobbed-5-0-gallon-gas-tank-set-wyatt-gatling-011579","provider":"ChopCult","version":"1.0","type":"link"}
