{"product_id":"bobbed-5-0-gallon-gas-tank-set-v-twin-38-0152-big-twin-1984-1999","title":"Bobbed 5.0 Gallon Gas Tank Set - V-Twin 38-0152 - Big Twin 1984-1999","description":"\u003cp\u003eGas tank is a two piece tank with a fuel capacity of 5.0 gallons and a left side petcock opening.\u003c\/p\u003e\n\u003cp\u003eFlatside tank features an updated shape which tapers from front to rear. Tank accepts caps for stock style bungs. Order caps separately. Please test fitment before painting. Tank weld seams may require filler to meet your individual requirements. Do not grind or sand the seams as this may cause leaks. We suggest using Kreem gas tank combo kit to clean condition and seal. This will help to stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 17-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 3 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 7-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 2 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 8-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height:\u003c\/li\u003e\n\u003cli\u003eTunnel Length:\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1986-1999\u003c\/td\u003e\n\u003ctd\u003eFLST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1984-1999\u003c\/td\u003e\n\u003ctd\u003eFXST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552812826782,"sku":"38-0152","price":199.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0152-bobbed-5-0-gallon-gas-tank-set-big-twin-1984-1999-1.jpg?v=1792131974","url":"https:\/\/chopcult.com\/products\/bobbed-5-0-gallon-gas-tank-set-v-twin-38-0152-big-twin-1984-1999","provider":"ChopCult","version":"1.0","type":"link"}
