{"product_id":"bobbed-4-0-gallon-gas-tank-raw-v-twin-38-0116-oem-61054-92a-big-twin-1982-1994","title":"Bobbed 4.0 Gallon Gas Tank Raw - V-Twin 38-0116 - OEM 61054-92A - Big Twin 1982-1994","description":"\u003cp\u003e\u003cstrong\u003eOEM #:\u003c\/strong\u003e 61054-92A\u003c\/p\u003e\n\u003cp\u003eRaw gas tank has a left side petcock location and has a fuel capacity of 4.0 gallons. Tank has a dash cutout and will bolt on with original hardware. Accepts GPS speedometer and tachometer dash kit\u003c\/p\u003e\n\u003cp\u003eRequires purchase of complete dash kit. Check the tank for flaws or fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. Order FXS dash panel kits available separately. Panels will accept 3 inch gauges. *NOTE: May be updated to FXR type dash panel with purchase of dash bracket must be aligned and welded in place. **Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 16 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 9 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 13-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 4 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 9 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 7 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 20 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Width: 4-5\/16 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Width: 3-1\/2 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with GPS Speedometer and Tachometer Dash Kit Chrome\u003c\/li\u003e\n\u003cli\u003eSuggested to use with GPS Speedometer and Tachometer Dash Kit Black\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Dash Cover Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Ratcheting Style Gas Cap Set Vented and Non-Vented Chrome\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Pingel Metric Hex Petcock Under Spigot with Nut Polished\u003c\/li\u003e\n\u003cli\u003eSuggested to use with FXRS Dash Bracket\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1982-1994\u003c\/td\u003e\n\u003ctd\u003eFXR\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67552811745438,"sku":"38-0116","price":309.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0116-bobbed-4-0-gallon-gas-tank-raw-oem-61054-92a-big-twin-1982-1994-1.jpg?v=1792131953","url":"https:\/\/chopcult.com\/products\/bobbed-4-0-gallon-gas-tank-raw-v-twin-38-0116-oem-61054-92a-big-twin-1982-1994","provider":"ChopCult","version":"1.0","type":"link"}
