{"product_id":"bobbed-4-0-gallon-gas-tank-kit-v-twin-38-0178-big-twin-1995-2005","title":"Bobbed 4.0 Gallon Gas Tank Kit - V-Twin 38-0178 - Big Twin 1995-2005","description":"\u003cp\u003eGas tank has a left side petcock opening and has a fuel capacity of 4.0 gallons. Tank kit includes chrome gas caps and a chrome cast dash with an adapter ring which allows the the reuse of an existing electronic speedometer.\u003c\/p\u003e\n\u003cp\u003eFor use on carbureted models only. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 18 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 10 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 14 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 1-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 8-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 7 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 17 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1995-2005\u003c\/td\u003e\n\u003ctd\u003eFXD\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67552812957854,"sku":"38-0178","price":539.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0178-bobbed-4-0-gallon-gas-tank-kit-big-twin-1995-2005-1.jpg?v=1792131977","url":"https:\/\/chopcult.com\/products\/bobbed-4-0-gallon-gas-tank-kit-v-twin-38-0178-big-twin-1995-2005","provider":"ChopCult","version":"1.0","type":"link"}
