{"product_id":"bobbed-3-2-gallon-gas-tank-kit-v-twin-38-0191-sportster-2004-2006","title":"Bobbed 3.2 Gallon Gas Tank Kit - V-Twin 38-0191 - Sportster 2004-2006","description":"\u003cp\u003eGas tank has a left side petcock opening and a fuel capacity of 3.2 gallons.\u003c\/p\u003e\n\u003cp\u003eTank kit features a chrome cast dash kit which includes dash with lens 6 post switch choke cable and knob mounting hardware and trim strips chrome late style bung caps. and all necessary mounting hardware for installation. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit clear condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock should be masked or plugged during painting for easy installation of petcock. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 16-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 7 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 13-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 2 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 8-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 8 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 2 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 17 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e2004-2006\u003c\/td\u003e\n\u003ctd\u003eXL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67552813318302,"sku":"38-0191","price":359.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0191-bobbed-3-2-gallon-gas-tank-kit-sportster-2004-2006-1.jpg?v=1792131982","url":"https:\/\/chopcult.com\/products\/bobbed-3-2-gallon-gas-tank-kit-v-twin-38-0191-sportster-2004-2006","provider":"ChopCult","version":"1.0","type":"link"}
