{"product_id":"black-12-volt-ignition-coil-3-0-ohms-volt-tech-74056","title":"Harley Big Twin Black 12 Volt Ignition Coil 3.0 Ohms - Volt Tech 74056","description":"\u003cp\u003eIgnition coil is steel jacketed and includes nuts packing and wires. The 12 volt coil replaces 31602-30 on 1930-1947 models with black finish. Use coil mount kit to clamp to frame tube. Includes suppression wires. Coils puts out 2 ohms. The right side is positive and the left side is negative. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. ***NOTE: Coils are factory tested before packaging. Full warranty thru the dealer where you purchased! Over 20 000 coils sold since 1990! *NOTE: Use wire terminal OEM #9913 on 1930-1947 models for distributor wires. Fits 1930-1947 Harley Flathead and Knucklehead models.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eVolt Tech #:\u003c\/strong\u003e 74056\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eUse coil mount kit for Big Twin models\u003c\/li\u003e\n\u003cli\u003eUse coil mount kit for Side Valve models\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1936-1940\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1947\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1938-1947\u003c\/td\u003e\n\u003ctd\u003eUL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1930-1934\u003c\/td\u003e\n\u003ctd\u003eVL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Volt Tech","offers":[{"title":"Default Title","offer_id":67551860326558,"sku":"32-8088","price":99.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-8088-black-12-volt-ignition-coil-3-0-ohms-volt-tech-74056-1.jpg?v=1792123832","url":"https:\/\/chopcult.com\/products\/black-12-volt-ignition-coil-3-0-ohms-volt-tech-74056","provider":"ChopCult","version":"1.0","type":"link"}
