Universal British
Amal Carburetor Gasket Set for 626 / 928 / 930 /932 series carbs
$9.99 USD
$9.99 USD
If you break open your Amal carburetor for a rebuild, then you'll want to use this kit to freshen up and replace old gaskets and seals. The kit includes the bowl gasket, banjo bolt and filter gaskets, O-rings for air mixture and throttle stop screw and manifold O-ring.
- For use with 626, 928, 930 and 932 Amal carbs
- 1 kit will accommodate 1 carburetor
