{"product_id":"80-shovelhead-cylinder-piston-kit-v-twin-11-2612","title":"80 Shovelhead Cylinder Piston Kit - V-Twin 11-2612","description":"\u003cp\u003eGME 80 inch Shovelhead cylinder and piston with genuine cast cylinders prefitted with 8:1 compression cast pistons and rings.\u003c\/p\u003e\n\u003cp\u003eSet of two. For stock stroke only. They are ready to run and will require break-in. Please refer to proper shop manual for suggestions on break-in. For 1979-1985 Shovelheads. Order head base gasket separately. May require the use of a cylinder base nut set available separately. The wrist pin are of the piston may require minor honing for proper fitment of the wrist pin. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eHeight of the Piston: 3-1\/4 inches\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use with #8601-8 Hi-Torque Cylinder Base Nut Set.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1979-1984\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1979-1983\u003c\/td\u003e\n\u003ctd\u003eFLT\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1979-1984\u003c\/td\u003e\n\u003ctd\u003eFX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1982-1983\u003c\/td\u003e\n\u003ctd\u003eFXR\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/Piston%20Fitment.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67549418225822,"sku":"11-2612","price":579.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/11-2612a.jpg?v=1791652410","url":"https:\/\/chopcult.com\/products\/80-shovelhead-cylinder-piston-kit-v-twin-11-2612","provider":"ChopCult","version":"1.0","type":"link"}
