{"product_id":"750-xr-rear-wheel-hub-alloy-v-twin-45-0107-ironhead-1957-1984","title":"750 XR Rear Wheel Hub Alloy - V-Twin 45-0107 - Ironhead 1957-1984","description":"\u003cp\u003e750 XR rear wheel hub features an alloy finish and includes 2 nuts. For 40 spoke hole rims.\u003c\/p\u003e\n\u003cp\u003eFeatures knock off threaded end for inchquick change inch rear sprockets. Includes 11\/16 bearings to fit stock sportster axles that are pre 1979 models and one lock nut. Accepts 11\/16 inch axle shaft and 6-8 gauge spokes. Accepts 38 tooth splined rear sprocket 49 tooth splined engine sprocket and 51 tooth splined engine sprocket. *NOTE: Alloy splined adapter is for sprocket and disc mounting. Disc mounting is a very close fit and should be tapped with rubber mallet - being careful not to damage splines. Order additional set of XR 750 hub lock nut separately.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eHub Length: 7-1\/8 inches\u003c\/li\u003e\n\u003cli\u003eCenter to Center: 1\/2 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with XR 750 Rear Hub Lock Nut Set Zinc.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with 38 Tooth Splined Rear Sprocket\u003c\/li\u003e\n\u003cli\u003eSuggested to use with 49 Tooth Splined Rear Sprocket.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with 51 Tooth Splined Rear Sprocket.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with 750 XL Rear Sprocket Adapter.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with 45 Tooth Splined Rear Sprocket.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with 49 Tooth Splined Rear Sprocket.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with 51 Tooth Splined Rear Sprocket.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1957-1984\u003c\/td\u003e\n\u003ctd\u003eXL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67553338294430,"sku":"45-0107","price":229.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/45-0107-750-xr-rear-wheel-hub-alloy-ironhead-1957-1984-1.jpg?v=1792136526","url":"https:\/\/chopcult.com\/products\/750-xr-rear-wheel-hub-alloy-v-twin-45-0107-ironhead-1957-1984","provider":"ChopCult","version":"1.0","type":"link"}
