{"product_id":"74-shovelhead-cylinder-and-piston-kit-v-twin-11-2603","title":"74 Shovelhead Cylinder and Piston Kit - V-Twin 11-2603","description":"\u003cp\u003e74 inch Shovelhead cylinder and piston kit honed and pre fitted with 8.5:1 compression cast pistons and rings\u003c\/p\u003e\n\u003cp\u003eThey are ready to run and will require break-in. Please refer to proper shop manual for suggestions on break-in. Sold in pairs. For stock stroke only. For 1966-1978 Shovelheads. order gasket set separately. *NOTE: All cast iron cylinders have same piston to wall clearance.0025 -.003. Bore size is 3.4380 inch-3.4385 inch inner diameter.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eRing Installation Note: The silver ring is on top with the chamfer and the writing facing up. The black ring is the second ring with writing facing up.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1966-1978\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1971-1978\u003c\/td\u003e\n\u003ctd\u003eFX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/Piston%20Fitment.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67549417996446,"sku":"11-2603","price":579.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/11-2603a.jpg?v=1791652396","url":"https:\/\/chopcult.com\/products\/74-shovelhead-cylinder-and-piston-kit-v-twin-11-2603","provider":"ChopCult","version":"1.0","type":"link"}
