{"product_id":"74-knucklehead-engine-assembly-v-twin-10-1388","title":"74 Knucklehead Engine Assembly - V-Twin 10-1388","description":"\u003cp\u003eReplica 74 inch long block Knucklehead with polished rocker boxes parkerized valve cover cups a Linkert bolt manifold the motor sprocket and an 18mm spark plug set. Fully assembled and tested for oil pressure.\u003c\/p\u003e\n\u003cp\u003eUnit features replica crank cases overhead oiler provision from timing cover cast iron type flywheel assembled with stock rods and Torrington rollers with steel cages a valve train with tappet assembly featuring Sifton lightning cam pushrods chrome pushrod covers and a finned cam cover. Replica cast iron cylinders are fitted with 8.5:1 pistons and Hasting rings replica cast iron oil pump assembly with early style iron cover and a distributor mechanical advance with corresponding relay mount with distributor post guide slot. Includes brass M-74 Linkert carburetor. *NOTE: M-74 Linkert carburetor is pre-run installed and tested within our Motor Shop. Running! Manufacturer's Bill of Sale supplied.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1947\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1947\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67549241770142,"sku":"10-1388","price":9959.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/10-1388a.jpg?v=1791646589","url":"https:\/\/chopcult.com\/products\/74-knucklehead-engine-assembly-v-twin-10-1388","provider":"ChopCult","version":"1.0","type":"link"}
