{"product_id":"6-volt-three-brush-solid-state-relay-volt-tech-77332-oem-74750-38","title":"6 Volt Three Brush Solid State Relay - Volt Tech 77332 - OEM 74750-38","description":"\u003cp\u003e\u003cstrong\u003eVolt Tech #:\u003c\/strong\u003e 77332 · \u003cstrong\u003eOEM #:\u003c\/strong\u003e 74750-38, 4785-38\u003c\/p\u003e\n\u003cp\u003eSolid state relay is 6 volt three terminal style with a smooth chrome cover. It replaces original style mechanical relay.\u003c\/p\u003e\n\u003cp\u003eRelay allows the use of charge indicating lamp on all 3-brush applicationsand is full function as a mechanical relay. The dash light will work.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eRelay end with single terminal is the armature connection. Battery connection is the lower terminal on the opposite end. Charge lamp is the upper terminal.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1938-1940\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1957\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1938-1948\u003c\/td\u003e\n\u003ctd\u003eUL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1938-1952\u003c\/td\u003e\n\u003ctd\u003eWL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/32\/32-0056.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Volt Tech","offers":[{"title":"Default Title","offer_id":67551687409822,"sku":"32-0056","price":74.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-0056-6-volt-three-brush-solid-state-relay-volt-tech-77332-oem-74750-38-1.jpg?v=1792121705","url":"https:\/\/chopcult.com\/products\/6-volt-three-brush-solid-state-relay-volt-tech-77332-oem-74750-38","provider":"ChopCult","version":"1.0","type":"link"}
