{"product_id":"6-volt-distributor-and-coil-kit-v-twin-32-1506","title":"6 Volt Distributor and Coil Kit - V-Twin 32-1506","description":"\u003cp\u003e6 volt distributor and coil kit features a chrome automatic advance distributor a metal jacketed chrome coil and vintage wire set with boots\u003c\/p\u003e\n\u003cp\u003e*NOTE: Drilling a hole in the plate helps to set advance when timing.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Ignition Advance with Points Plate Assembly.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Chrome Distributor Cover.\u003c\/li\u003e\n\u003cli\u003ePoints go on the front side for ease of adjusting. Both lobes should open \u0026amp; close points but the skinny lobe times the front cyclinder see service manual.\u003c\/li\u003e\n\u003cli\u003eThere is no mark on the cam. Must time at cylinder top dead center. Unit requires removal of front head for installation.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1948-1960\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/32\/32-1506.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Volt Tech","offers":[{"title":"Default Title","offer_id":67551794528414,"sku":"32-1506","price":269.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-1506-6-volt-distributor-and-coil-kit-1.jpg?v=1792122821","url":"https:\/\/chopcult.com\/products\/6-volt-distributor-and-coil-kit-v-twin-32-1506","provider":"ChopCult","version":"1.0","type":"link"}
