{"product_id":"45-wl-gas-and-oil-tank-kit-v-twin-38-1286","title":"45 WL Gas and Oil Tank Kit - V-Twin 38-1286","description":"\u003cp\u003eGas and oil tank kit includes emblem stainless steel trim mounts welded in place shift lever gas and oil caps and full shut off rod assembly. Tank set accepts cateye dash.\u003c\/p\u003e\n\u003cp\u003eTank set is correct for 1940-1946 WL and G models but will fit 1937-1973 G and 1937-1952 W models. 45 inch tank set space as required to allow fitting dash base and cover use 5\/16 inch inner diameter washer between tanks and frame. *NOTE: Must order trim strip and shut off rod assembly separately. Order gate 3 speed and reverse or 3 speed separately. **NOTE: Order correct shifter gate as required 1936-46 type.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Stainless Steel Emblem Trim Set\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Army 45 Shifter Gate\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Chrome Left Side Tank Hand Shifter Gate\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1940-1946\u003c\/td\u003e\n\u003ctd\u003eG\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1940-1946\u003c\/td\u003e\n\u003ctd\u003eWL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67552860078238,"sku":"38-1286","price":889.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-1286-45-wl-gas-and-oil-tank-kit-1.jpg?v=1792132493","url":"https:\/\/chopcult.com\/products\/45-wl-gas-and-oil-tank-kit-v-twin-38-1286","provider":"ChopCult","version":"1.0","type":"link"}
