{"product_id":"45-w-transmission-4-speed-gear-kit-v-twin-49-0683","title":"45 W Transmission 4-Speed Gear Kit - V-Twin 49-0683","description":"\u003cp\u003e45 inch W 4-speed transmission gear kit includes first 2nd 3rd gear cluster gear main clutch gear 3\/4 shifter clutch 1\/2 shifter clutch and shifter drum.\u003c\/p\u003e\n\u003cp\u003eKit is 10 pieces as shown in the photos. Includes all gears shifter drum and side cover. Kit can be used on Solo machines and Servi-cars to transform 45 inch3 speed transmission into 4 speed transmission. With the 4 speed conversion in a 45 inch transmission the reverse gear option CANNOT be installed. Kit uses the stock type mainshaft countershaft shifter forks and hardware. First gear forward. *NOTE: Requires 4-speed shifter gate. **NOTE: Requires side cover holes to be enlarged in transmission case and needs a stud set available separately. *** NOTE: 4 speed gear ratios will be: 1st - 2.67:1 2nd - 2.03:1 3rd 1.42:1 a 4th 1:1. Stock 3 speed gear ratios are: 1st - 2.47:1 2nd - 1.57:1 and 3rd - 1.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eRequired to use with #17-1927 Sprocket Cover Mount Stud Set Parkerized.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1941-1952\u003c\/td\u003e\n\u003ctd\u003eW\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67553833713822,"sku":"49-0683","price":719.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/49-0683-45-w-transmission-4-speed-gear-kit-1.jpg?v=1792138587","url":"https:\/\/chopcult.com\/products\/45-w-transmission-4-speed-gear-kit-v-twin-49-0683","provider":"ChopCult","version":"1.0","type":"link"}
