{"product_id":"45-w-g-transmission-case-v-twin-49-0172-oem-34702-41","title":"Harley Flathead 45 W\/G Transmission Case - V-Twin 49-0172 - OEM 34702-41","description":"\u003cp\u003e45 inch W\/G transmission case. Case accepts: 3-speed 3-speed and reverse and 4-speed internals. *NOTE: 45 inch W\/G transmission case requires components and hardware as listed for assembly separately. *NOTE: Bottom mount studs left countershaft transmission bushing both the inner and outer shifter bushings with the welch plug and the cam plunger bushing are installed. *NOTE: The main race required available separately has to be pressed in must be honed after installation. Installation instructions (PDF). Fits 1937-1963 Harley Flathead models.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eOEM #:\u003c\/strong\u003e 34702-41, 2258-41\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eRequired to use with Cam Bushing.005 Oversize. Required to use with Engine Case 1\/2inch Welch Plug. Required to use with #9919-3 Transmission Bottom Stud Kit.\u003c\/li\u003e\n\u003cli\u003eRequired to use with Transmission Shifter Shaft Bushing Large. Required to use with Shifter Shaft Bushing Small.\u003c\/li\u003e\n\u003cli\u003eRequired to use with Left Countershaft Transmission Bushing. Required to use with #2655-1 Transmission Fill Plug.\u003c\/li\u003e\n\u003cli\u003eRequired to use with #9761-4 Kick Starter Trip Bolt and Nut Kit. Required to use with Transmission Case Cover. Required to use with Servi-Car Reverse Idler Shaft.\u003c\/li\u003e\n\u003cli\u003eRequired to use with Transmission Side Cover for on 4-speed Transmission Case. Required to use with #9836-10 Chrome Countersunk Washer Set 3\/8inch.\u003c\/li\u003e\n\u003cli\u003eRequired to use with #9686-16 Sprocket Cover Stud Nut Kit Parkerized. Required to use with #9666-27 Transmission Top and Side Cover Screw Kit Parkerized.\u003c\/li\u003e\n\u003cli\u003eRequired to use with 2nd Gear Retaining Bracket.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1937-1963\u003c\/td\u003e\n\u003ctd\u003eG\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1952\u003c\/td\u003e\n\u003ctd\u003eW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1937-1939\u003c\/td\u003e\n\u003ctd\u003eWL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67553804681374,"sku":"49-0172","price":609.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/49-0172-45-w-g-transmission-case-oem-34702-41-1.jpg?v=1792138316","url":"https:\/\/chopcult.com\/products\/45-w-g-transmission-case-v-twin-49-0172-oem-34702-41","provider":"ChopCult","version":"1.0","type":"link"}
