{"product_id":"45-gas-and-oil-tank-set-v-twin-38-0860","title":"45 Gas and Oil Tank Set - V-Twin 38-0860","description":"\u003cp\u003eRaw tank set accepts gas shut off rod kit. Set includes tank emblem mount strips only which can be used for restoration on 1947-1950 models.\u003c\/p\u003e\n\u003cp\u003eTank set is an accurate reproduction of the stock gas\/oil tank combinationwith the fuel shut off rod feature. *NOTE: Tank set accepts 2 3 and cast lite dash and later 1947-1973 shifter gate for W2 and g model servi-cars. May require fuel rod and oil tank fittings alignment using V-Twin before applying paint. 45 tank set space as required to allow fitting dash base and cover use 5\/16 inch inner diameter washer between tanks and frame. *NOTE: Must order emblem set separately.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eGas Capacity: 3.5 Gallon\u003c\/li\u003e\n\u003cli\u003eOil Capacity: 3.4 Quart\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1947-1957\u003c\/td\u003e\n\u003ctd\u003eG\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1947-1952\u003c\/td\u003e\n\u003ctd\u003eW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/38\/38-0860.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552855130270,"sku":"38-0860","price":669.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0860-45-gas-and-oil-tank-set-1.jpg?v=1792132392","url":"https:\/\/chopcult.com\/products\/45-gas-and-oil-tank-set-v-twin-38-0860","provider":"ChopCult","version":"1.0","type":"link"}
