{"product_id":"4-speed-transmission-case-es-v-twin-43-9105-oem-34702-78","title":"4-Speed Transmission Case ES - V-Twin 43-9105 - OEM 34702-78","description":"\u003cp\u003e\u003cstrong\u003eOEM #:\u003c\/strong\u003e 34702-78\u003c\/p\u003e\n\u003cp\u003eES 4-speed transmission case accepts ratchet top.\u003c\/p\u003e\n\u003cp\u003eCase uses mainshaft bearing Torrington needle type and reverse gear idler shaft (not the 88 loose rollers). Loctite recommended for mount stud installation. No Manufacturer's Statement of Origin required Bill of Sale only. *NOTE: Bushings are not installed. **NOTE: Technician must remove\/check material for speedometer drive clearance.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eAccepts Torrington style 4th gear bearing.\u003c\/li\u003e\n\u003cli\u003eSuggested to use bearing retainer on 1981-1984\u003c\/li\u003e\n\u003cli\u003eSuggested to use housing on 1981-1984 models\u003c\/li\u003e\n\u003cli\u003eBill Of Sale Only.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1977-1979\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1977-1978\u003c\/td\u003e\n\u003ctd\u003eFX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67553237860510,"sku":"43-9105","price":389.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/43-9105-4-speed-transmission-case-es-oem-34702-78-1.jpg?v=1792135654","url":"https:\/\/chopcult.com\/products\/4-speed-transmission-case-es-v-twin-43-9105-oem-34702-78","provider":"ChopCult","version":"1.0","type":"link"}
