{"product_id":"4-speed-big-twin-transmission-assembly-v-twin-17-0275","title":"4-Speed Big Twin Transmission Assembly - V-Twin 17-0275","description":"\u003cp\u003e4-speed 1970-1984 FL transmission assembly includes FL ration gears ratchet top and kicker cover assembly. Largest main shaft is 12-1\/2 inch.\u003c\/p\u003e\n\u003cp\u003eReplica 4-speed transmission with a 3.00 ratio features cast case internal parts chrome kicker cover and components longest transmission clutch rod throwout bearing natural finish ratchet top with chrome dust cover clutch arm mount studs hub nut seal and key. Transmission is fully assembled for Big Twin models. Cases have mount lugs to accept aluminum inner primary covers. Speedometer drive gear is supplied and has a 1:1 ratio. Torrington needle bearings are used throughout. The shift pattern will be reversed when installed in mid-shift as it has the FL type ratchet top to be used with forward controls. No Manufacturer's Statement of Origin required Bill of Sale only. *NOTE: Kick starter cover studs are supplied for the kick starter only: for battery box starter bracket FXE brake pedal mount and FLH passenger footpeg mount longer studs are required.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1970-1984\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67550153769118,"sku":"17-0275","price":2279.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/17-0275-4-speed-big-twin-transmission-assembly-1.jpg?v=1792107791","url":"https:\/\/chopcult.com\/products\/4-speed-big-twin-transmission-assembly-v-twin-17-0275","provider":"ChopCult","version":"1.0","type":"link"}
