{"product_id":"4-speed-big-twin-transmission-assembly-v-twin-17-0005","title":"4-Speed Big Twin Transmission Assembly - V-Twin 17-0005","description":"\u003cp\u003eComplete 1970-1984 FL transmission assembly is 4-speed. Includes FL ratio gears.\u003c\/p\u003e\n\u003cp\u003eReplica 4-speed transmission with a 3.00 ratio features cast case internal parts chrome kicker cover and components longest transmission clutch rod throwout bearing natural finish ratchet top with chrome dust cover clutch arm mount studs hub nut seal and key. Transmission is fully assembled for Big Twin models. Cases have mount lugs to accept aluminum inner primary covers. Speedometer drive gear is supplied and has a 1:1 ratio. Torrington needle bearings are used throughout. The shift pattern will be reversed when installed in mid-shift as it has the FL type ratchet top to be used with forward controls. No Manufacturer's Statement of Origin required Bill of Sale only. *NOTE: Kick starter cover studs are supplied for the kick start models only. For electric start models longer studs are required.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Kick Starter Cover Stud Set.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with #9637-13 Transmission Kick Starter Cover Stud Kit.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1970-1984\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67550145118366,"sku":"17-0005","price":1909.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/17-0005-4-speed-big-twin-transmission-assembly-1.jpg?v=1792107561","url":"https:\/\/chopcult.com\/products\/4-speed-big-twin-transmission-assembly-v-twin-17-0005","provider":"ChopCult","version":"1.0","type":"link"}
