{"product_id":"24-tooth-transmission-sprocket-york-26-0006-24","title":"24 Tooth Transmission Sprocket - York 26-0006-24","description":"\u003cp\u003e\u003cstrong\u003eYork #:\u003c\/strong\u003e 26-0006-24\u003c\/p\u003e\n\u003cp\u003eThis 24 Tooth transmission sprocket has 2 holes and a.810 inch offset. For 5 speed models.\u003c\/p\u003e\n\u003cp\u003eIt allows the installation of a 180 tire without transmission offset. The maximum offset without any modification to the stock inner primary is.900 inch.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eHeight: 1-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eInner Diameter: 3-29\/32 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003e.810inch offset is measured from the back side of the teeth to the back side of the sprocket excluding the flange.\u003c\/li\u003e\n\u003cli\u003e1.236inch offset is measured from the center line of the teeth to the top of the flange on the back side of the sprocket.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Pulley Indexing Flange Nut.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"York","offers":[{"title":"Default Title","offer_id":67550239031454,"sku":"19-0216","price":79.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/19-0216.jpg?v=1791667449","url":"https:\/\/chopcult.com\/products\/24-tooth-transmission-sprocket-york-26-0006-24","provider":"ChopCult","version":"1.0","type":"link"}
