{"product_id":"1937-1938-el-knucklehead-bare-cylinder-head-set-v-twin-49-1310","title":"1937-1938 EL Knucklehead Bare Cylinder Head Set - V-Twin 49-1310","description":"\u003cp\u003e1937-1938 EL bare Knucklehead head set features OEM production numbers mc hallmark small intake port primer black plugs manifold nipples and are painted with black heat paint.\u003c\/p\u003e\n\u003cp\u003eExact for 1937 only but can be used on 1937-1939 61 inch EL models. Either type of valve spring cover can be installed either cup type of full cover and top set. Accepts inchBaby Butt inch intake manifold springs valves collars spring cups and top tins included and assembled. *NOTE: Valve seats are installed but not cut. Uses 1-3\/8 inch large hex 18mm plugs. *NOTE: Heads include feature detailed casting hallmarks as original black painted. *NOTE: Accepts large 1-3\/8 inch hex Doering #3 spark plug set. Material of valve seats features a better hardenability and heat resistance than 1.2713. Material is tough with high compressive strength and high tempering resistance. Hardness equals 370-415 HB. Tensile strength equals 1250-1400 N\/mn2. Condition is tempered.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with 18mm Doering Spark Plug Set.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with 18mm Doering Spark Plug Set.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1937-1938\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/49\/49-1310.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Motortechnic","offers":[{"title":"Default Title","offer_id":67553870381214,"sku":"49-1310","price":4579.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/49-1310-1937-1938-el-knucklehead-bare-cylinder-head-set-1.jpg?v=1792139000","url":"https:\/\/chopcult.com\/products\/1937-1938-el-knucklehead-bare-cylinder-head-set-v-twin-49-1310","provider":"ChopCult","version":"1.0","type":"link"}
