{"product_id":"1-hole-crank-pin-with-nuts-v-twin-10-0685","title":"1-Hole Crank Pin with Nuts - V-Twin 10-0685","description":"\u003cp\u003eNew Old Stock inch 1-hole crank pin with nuts is original Army Surplus used on 45 inch models.\u003c\/p\u003e\n\u003cp\u003eHas a wax and cosmoline oil coating which will needs to be carefully removed with a razor blade. You must align oil feed in flywheels with crank pin. OEM uses 2 different flywheels so hole location may differ. This crank pin includes 2 oil feed holes to fit both the early and later flywheels. The distance measured from the edge not including the threads is 2.516 inch.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1937-1973\u003c\/td\u003e\n\u003ctd\u003eG\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1937-1952\u003c\/td\u003e\n\u003ctd\u003eW\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Eastern","offers":[{"title":"Default Title","offer_id":67549211099294,"sku":"10-0685","price":64.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/10-0685a.jpg?v=1791645923","url":"https:\/\/chopcult.com\/products\/1-hole-crank-pin-with-nuts-v-twin-10-0685","provider":"ChopCult","version":"1.0","type":"link"}
